21-12-2012, 06:58 PM
rept you still running 100% veg oil or mixing it? iam still running 100% oil seems fine even through the bad spell we had weather wise also has your fuel system found any leaks yet when you been using the oil?
Running veg? Power loss?
21-12-2012, 07:38 PM
(21-12-2012, 06:58 PM)vincent1 Wrote: rept you still running 100% veg oil or mixing it? iam still running 100% oil seems fine even through the bad spell we had weather wise also has your fuel system found any leaks yet when you been using the oil? Running 100% veg. Adding 40l veg+petrol+more veg on next topup. no leaks! Dont know where to chexk for them, so im safe to say :p
21-12-2012, 08:33 PM
been running veg for about 2 years leak of pipes are leaking (got new to replace) and the throttle shaft seals leaking bad (got a seal kit) just to cold to do it lol can wait till warmer weather. i am using tesco at richo arena at the minute still 10 liters for £10.00 just there own brand cooking oil runs good on it though.
21-12-2012, 09:29 PM
Other than changing to a Bosch pump is there anything else that needs doing to the car to start running veg oil?
21-12-2012, 09:42 PM
(21-12-2012, 09:29 PM)RJDubya Wrote: Other than changing to a Bosch pump is there anything else that needs doing to the car to start running veg oil? Just the bosch
23-12-2012, 05:13 PM
have lots of spare fuel filters ready. Youll probably need to change one within the first few hundred miles and then again at a few hundred more.
23-12-2012, 06:34 PM
Ive done 300 miles since veg, got a service kit that needs doing ^_^, so im well planned. Why will i have to change again so soon?
BIG POWER!! WHAT YOU RUNNING? | Logue1996 | 7 | 2,774 |
10-09-2017, 11:23 AM Last Post: Dave |
Loss of power | Nathan1305 | 14 | 3,558 |
22-09-2014, 07:44 PM Last Post: kentiiboii |
Loss of Boost/Power | Mike | 10 | 1,956 |
04-07-2014, 07:30 PM Last Post: Mike |
