Accelerator pedal stiff
In my dturbo when i push down on the acc pedal its real stiff, if i get someone to move the throttle cable when doing im pushing the pedal its as it should be, when left alone it goes back the way it was.. Any ideas? Thanks
Just want to get this sorted as quickly as possible as have a long journey coming up!
Does the throttle arm on the pump feel stiff as well or just from the pedal? You may just need some wd40 on the cable
HDi Cabby Project Click
No its good on the throttle arm! I can fix the stiffness at the pedal if someone plays with the throttle cable itself
Get a new cable or scrappy and blag one lol... Or be cheap like me and try to oil the one on there haha
Whats the best way to get wd-40 on the cable? I presume its just put it under the rubber nearest the throttle arm and spray.. I wont be looking at it till tomorrow morning so just curious
Mine was the same, I rathered a stiff peddle than a floppy peddle lmao
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
(03-12-2012, 07:07 PM)Bananalad Wrote: Whats the best way to get wd-40 on the cable? I presume its just put it under the rubber nearest the throttle arm and spray.. I wont be looking at it till tomorrow morning so just curious
Yea, thats the way I did it, just keep pumping the pedal/moving the throttle arm while you spray, it may take a while for the oil to get all the way in so be patient!
Disconnect it and stand on the slam panel holding the cable up. Gravity will help you lube down Wink
  Stiff Throttle Pedal r3k1355 2 2,165 21-01-2014, 07:08 PM
  Accelerator cable devils_fuel 7 5,062 19-10-2013, 09:22 PM
Last Post: devils_fuel
  Clutch and Accelerator Cables Ash J 4 3,625 22-01-2013, 01:18 AM
Last Post: samass
