rattley vibration sort of sound
May be able to help me if poss i think either one of the pulleys or could be the cam belt tensioner is rattling some times not alot but most of the time really lould how would i be able to find out what it is without paying stupid money for a garage to check it out? Many thanks
Remove the aux belt and check all your pulleys and tensioners by hand. The usual suspect is the crank pulley on these engines.
(02-12-2012, 09:57 PM)Poodle Wrote: Remove the aux belt and check all your pulleys and tensioners by hand. The usual suspect is the crank pulley on these engines.
When you say check by hand do you mean see if theres play in them? Thanks for the help appreciated
Hi,
For reference this is the noise my crank pulley made when it was gone - Worn Pulley
and after it was fixed - Fixed Pulley
Hope this helps!
Geoff
Yeah, any play or sticky/graunchy feeling in them.
Thanks sport1901966, that's a pretty useful recording.
Thanks for the help guys for some reason the recording wont play?
  Hdi - non starter (sort of) New injectors PP2000 data inside londondan86 37 7,014 09-06-2014, 04:36 PM
Last Post: Toms306
  Engine Vibration Felt Throughout Revs Tom85 2 1,096 21-12-2013, 08:00 PM
Last Post: Tom85
  Vibration Donkeybubles 3 1,071 08-12-2013, 09:22 PM
Last Post: titch
