08-12-2013, 07:14 PM
1st I have a vibration frew the gear stick steering wheel and pedals pretty much all the time since I lowered my car 60mm hope someone has came across this before cheers lads
Vibration
08-12-2013, 09:05 PM
Something must be fouling, have a look around. Start with bits that were taken off or will have changed position relative to the chassis when you lowered the car - exhaust, wishbones, driveshafts, etc.
08-12-2013, 09:10 PM
lower engine mount.
check first what has changed... Wishes for more power...
08-12-2013, 09:22 PM
As piggy said above, the lower engine mount can cause this, i had the same problem and i changed the lower engine mount and the gearbox one and all smooth again.
I would look first at what you have changed recently if you have just lowered it, and it didn't do it before. |
| Engine Vibration Felt Throughout Revs | Tom85 | 2 | 2,299 |
21-12-2013, 08:00 PM Last Post: Tom85 |
| rattley vibration sort of sound | dan wiltshire | 5 | 3,996 |
03-12-2012, 02:02 PM Last Post: dan wiltshire |
