PH1 Lock/unlock from key?! Also speedo problem..
Does anyone know if the PH1's came with this on the key?.. Its just it looks like the main key i have for my Sedan Dturbo has a button, just like the one i had for a ph2 dturbo and I press it but theres no glow of a red light on the bottom so im guessing the battery was long dead!.
The sedan is 1996, SRTD and has electric windows if that helps with the answer?
Also my speedo sort of works if you get me, it sticks around 60mph, but the very odd time it will knock down to 0mph and go up to your current speed and work perfect like normal till you turn the car off. Is this the sensor on the gearbox doing this?
Thanks.
I have got the same prob with my speedo on mine but mine sits of the clock untill i've driven it for a bit then it will jump back down to zero then work Confused, i know they have a sensor on the gearbox and by the wheel but it could be your clock like mine which is not being easy to find Sad
  Wiper problem and speedo seriously confused ! MrHdi123 9 6,101 19-03-2013, 08:55 AM
Last Post: MrHdi123
