Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
Been looking around at getting a new lump for the new year and come across a decent 406, bosch pumped etc.
Question; the semi-ECU controlled advancing system on the fuel pumps; how can this be removed/overwritten?
and also, just to confirm, these blocks were the DHX lumps similarly to the modern Xantia XUD's? with the coated pistons etc?
Have i got this right?
much love x
Phaes 1 GTI 6 - Onyx Black
Threads: 119
5
Car Model/Spec: MG ZS180
Replace the pump with a normal Bosch.
Threads: 100
12
Car Model/Spec: 306 dturbo Ultra Spec
I thought it was only the DHYs that had the coating on the pistons.
Threads: 376
38
(30-11-2012, 03:10 PM)Ricky Wrote: Replace the pump with a normal Bosch.
I didn't know if it was easier to remove the semi-ECU system? than having to cam/time everything again
(30-11-2012, 03:11 PM)Pompey306mark Wrote: I thought it was only the DHYs that had the coating on the pistons.
hmm? I just assumed it was on the newer 406/Xantia's ? Mix of information from a seller and online bits..
Threads: 28
2
Car Model/Spec: Phase 4 Silver HDi Estate
afaik the dhx has coating too
Threads: 376
38
(30-11-2012, 03:57 PM)Kwik Wrote: afaik the dhx has coating too
Ideal!
Thanks for that info; as for the fuel pump advancing issue? anyway to overcome this?
Threads: 100
12
Rip off new Bosch and replace with old style one.
Threads: 119
5
Yeah the only way to do it is swap the pump. It's really easy to do it while the engine is out anyway.
Threads: 376
38
i suppose; i could give it a go, not too difficult.
Threads: 376
38
pm me
Threads: 119
5
To be honest if you're getting a new lump then it makes sense to change the belt etc anyway, I've just fitted a dhx myself and swapped the pump for a proper one.
Threads: 28
3
Hmmmm tell me about these coated pistons? The only annoyance about the pump on mine is that it's armoured and I can't adjust the main fuel screw :/ Otherwise business as usual.
Threads: 28
2
iirc the semi ecu pump goes further then the non ecu pump
Threads: 376
38
Spoke to Ruan about this and it's a pita to try and compute a semi ECU pump; easier to just put a normal Bosch on
