Door Locking problem . .NOT LOOMS! . . please look in
Exclamation
Bloody front passenger door won't lock . . . .locks are bouncing, the door itsself you can not physically move the metal rod up or down, it seems stuck in the up position, i've had the door card off . . .sprayed loads of wd40 in there and tried working it up and down but it just won't budge . . . .getting pissed off now and i can't lock the car which is obviously not very clever . .
any ideas boys? . . . . i'm clean out atm . . .
Cheers, Matt . . .
can you use the key in the lock to lock it? if not, id suggest a new lock unit (not the barrel)
(25-11-2012, 04:16 PM)Niall Wrote: can you use the key in the lock to lock it? if not, id suggest a new lock unit (not the barrel)
errrr no . . the key doesn't fit the passenger side lol otherwise i'd disconnect the central locking on that side and use the key . . . . .. .honestly ffs . . . .it's difficult to see what's going on in there as well, there isn't much room to maneuver . . .
nope its pretty gay trying to work on them lol. if your sure its not the loom (assume you have done a continuity test on all the wires?) then check the drivers one as well and if not that, one of the door locks is faulty.
(25-11-2012, 04:24 PM)Niall Wrote: nope its pretty gay trying to work on them lol. if your sure its not the loom (assume you have done a continuity test on all the wires?) then check the drivers one as well and if not that, one of the door locks is faulty.
it's just weird mate . . . . the rod that attaches to the button will not move up or down . . . . it is quite frankly G.A.F. . . . . Big Grin
it wont if the door is open. get in the car and fully close the door then it should drop
(25-11-2012, 04:33 PM)Niall Wrote: it wont if the door is open. get in the car and fully close the door then it should drop
seriously?. . . . . .if so i'm a bell end, could just be looms after all then mate, thanks for giving me food for thought . . .x
yeah you cant put the locks down unless the doors are closed. in which case, is more than likely door loom...probably drivers.
(25-11-2012, 04:40 PM)Niall Wrote: yeah you cant put the locks down unless the doors are closed. in which case, is more than likely door loom...probably drivers.
driver's already been fixed with previous owner by a garage . . . . oh well multi meter, stanley knife, soldering iron and electrical tape out tomoz then . .it's not like i haven't done it before . . lol
Sounds like the locking mechs had it if its lock and unlockin and wiring is fine bud
[Image: J5hxCcC.jpg]
(25-11-2012, 07:02 PM)CJ_Derv Wrote: Sounds like the locking mechs had it if its lock and unlockin and wiring is fine bud
gonna check wiring tomorrow and find out . .Smile
The check the contacts in the big plugs in the Door connection bud i had a pin corroded hence my window no opening at RR and made a new harness from the blaze one that had smashed the connector to door mech, pins,
I had same problem and passenger barrell bin smoothed so couldnt lock either if it wont let you puch down when closed it will be door mech id say they same on 3/5 door too btw as i got a 5 on my 3door
Hope this helps Big Grin
try unplug the passenger door mech and close door and see if rest of car locks
seems like i've managed to free it off now and it's back working . .Big Grin . .let's hope it lasts :p
door mech stocking then? Hopefully dude, im still driving round with a pin missing as got pissed off with drivers side haha
(26-11-2012, 12:32 PM)CJ_Derv Wrote: door mech stocking then? Hopefully dude, im still driving round with a pin missing as got pissed off with drivers side haha
maybe yeah . . .i drenched that shit in wd40 yesterday and it's been ok today so fingers crossed . .Smile
you do realise if the bar is bent could give exactly same symptoms yea?
(30-11-2012, 01:04 AM)Kwik Wrote: you do realise if the bar is bent could give exactly same symptoms yea?
yeah for sure . . .i just wd40'd the fcuk out of it and it's been working since . .Big Grin
lol best thing to do is take door card off and make sure all the bars are straightish if it happens again
(30-11-2012, 10:55 AM)Kwik Wrote: lol best thing to do is take door card off and make sure all the bars are straightish if it happens again
Im having this problem again Sad ripped the bar for the pin out a few weeks when window dropped and lost me rag, but seems to be doing it again. now after a few attempts the fob stops and i can lock and unlock just drivers door and nothing else locks so u rekon its door mech on drivers?/
i would lube the mech up with some spray oil not wd40 as thats water dispersal and only leaves a very thin layer of oil
Found the problem previous owner used plastic crimps on some wires in loom and wired give way cos they farr too big for rubber inbetween door so cut them all out n soldered jobs a gooden Wink
Wink Door Loom Swapped - Central Locking Fault! partybish 8 6,283 29-09-2017, 08:58 PM
Last Post: paulgtt
  Door wiring looms Dturbo lad 2 2,398 03-01-2015, 12:31 PM
Last Post: Dturbo lad
  Zx central locking problem clarkey2010 1 2,109 10-10-2014, 06:37 AM
Last Post: Piggy
