stop light
Hi all.
I have had a new a/c rad fitted,cold air great.Since then the engine stop light stays illuminated all the time. Engine is ok. runs ok too. Has anyone else had this prob? A code was found and reset,but still the same. Engine is hdi2.0 in 306 2001. Any info please.
Cheers pugboy
Just for reference in case anyone else finds this fault - the problem relates to an electrical problem where when the 'AC' button is pressed on the dash, the stop light will illuminate on the instrument cluster. I believe this is due to a faulty relay or wiring which makes the ECU think that the car is overheating. If you press the AC button so that it's off, the stop light should go off.
  Fan always on + STOP light on dashboard arooscroocked 20 12,635 03-02-2018, 01:50 AM
Last Post: arooscroocked
  Stop light flashing on and off Welshy_Pete 15 8,934 20-03-2016, 08:07 PM
Last Post: Welshy_Pete
  noise behind glovebox aircon and stop light tomd306 11 5,657 29-04-2015, 09:26 AM
Last Post: highwayman306
