setting the alarm ph2
when alarms are set are the indicators always supposed to flash?
mine don't .....
also I have no red blinky light inside anywhere?!
[Image: signiture.jpg]
I'm not sure if they all have alarms. My ph1 d turbo doesn't so that doesn't flash the indicators but my S16 does
should have said, it defenitely has an alarm, I found it when I had the bumper off last, s at some point it must have worked
Ah right. I fort that if they don't have the red light inside they don't have an alarm. Might be different in the ph2s
I don't think ph2's have any logic, its a french car Smile
little box on passenger side behind the fog light, and an extra horn I guess is part of it too?
I'm not sure. I don't think I have ever heard an alarm go off on a 306
Mine used to all the time on the sedan!
There should be a button on the steering column iirc looks a bit like
Think it arms on the deadlock iirc and there's a key hole under the bonnet near the N/S headlight (may have a rubber cap on) that activates/deactivates it.
yup defenitely got that switch/button on the steering column, think they're used for resetting or similar that right?
will have a look under the bonnet for the lock, may have been faulty in the past so just turned off rather than fixed, so another thing to try and fix, or strip off and throw in the bin ....
Yeah something like that, think its something to do with the motion sensors tbh, like if you've left a dog in or something??
You'll see it it's either on the slam panel or on the wing, can't remember tbh!
They are all a bit temperamental tbh, like I said my sedan was always going off!
it should always flash repeatedly on unlocking with the fob and flash once on locking. They dont flash if you use the key in the barrel and this also doesnt set the alarm. alarm sets straight away on locking with the fob.
(18-11-2012, 09:45 PM)Oil-burner Wrote: Mine used to all the time on the sedan!
can't see a key hole anywhere just been out to have a look, is a rubber button like thing behind the battery, opped the cover off no key hole, and nothing else obvius around?!
(18-11-2012, 10:25 PM)Niall Wrote: it should always flash repeatedly on unlocking with the fob and flash once on locking. They dont flash if you use the key in the barrel and this also doesnt set the alarm. alarm sets straight away on locking with the fob.
no flashing lighst anytime, always lock it on the fob it just locks and then dead locks but no flashing indicators?!
think I'll have to have a better look in the light see what I can see, must be disabled somewhere
There definitely was on my ph1, should say something in Haynes if you've got one knocking around.
Think it was closer to the front iirc.
maybe tucked in around the abs stuff under the wing there, going to get the torch and have a nother look
Let me know how it goes, if not I'll check Haynes for you tomorrow.
nope no key thing there. Confused
only thing I'm not sure what it is is button type thing behind the ecu, sounds just like you described but no key inside, checked in the ecu box and everything, nothing Confused confused ...
Hmmm best thing to do is check in daylight tomorrow, or I'll look in Haynes after work.
yup my plan, too cold and dark atm, and my torch is shit!
nice one would be a great help, cheers
No worries mate, I'll look when I get home.
Only the phase 1 had the key under the bonnet behind the pass head light iirc
(18-11-2012, 11:10 PM)kernow_joe Wrote: nope no key thing there. Confused
red top if so that will be the inertia i think it is cut off switch
My ph1 had the alarm with the key behind the passenger headlight, sensors in the A pillars and the button on the steering column shroud.
The Haynes manual says the button can be used to turn the sensors on the A pillars on or off.
My Ph2 Dtub is always locked and unlocked off the key and the lights don't flash, oh I also don't have the little red flashing led on the center vent surround.
When I phoned up for insurance when I bought the car the insurance company asked me if it had an alarm and then they said oh hang on its thatcham cat2 from the factory so I'm like ok if you say so.
(19-11-2012, 12:43 AM)ash240970 Wrote: My ph1 had the alarm with the key behind the passenger headlight, sensors in the A pillars and the button on the steering column shroud.
yes the button can be used to turn the sensors on the A pillars on or off. this is incase you want to leave ur dog exc in the car while you lock it and go in the shop Wink
Lock it and leave a window open then wave your arm in and see if it goes off?
if you have a defender alarm system your indicators flash off and on and the led flashes on dash. if you just have the immobiliser no flashing anything, strange but true
Is it possible to fit the defender system instead of just the immobiliser?
the defender is an upgrade system not a standalone system
Sounds good to me bud what bits do I need to ra*e off another car?
if you got access to the 306 modifying haynes all the bits needed are in there
No ain't got it - didn't know there was one lol
/goesandsitsinshame
the haynes has full instructions also Click For Alarm that may fit
May be worthwhile messaging seller and asking is it a defender upgrade kit
I'm confused as mine doesn't flash or have a flashing light on the dash, so should be just immobiliser, but I've got an alarm under the passenger wing?!
  Alarm. Paulb306 0 2,250 20-03-2016, 02:57 PM
Last Post: Paulb306
  alarm box John1.4 12 8,086 20-02-2015, 03:33 PM
Last Post: pug306driver
  rf key fob alarm pug306driver 0 1,929 28-01-2015, 11:14 AM
