![[Image: 20121118_193453.jpg]](http://i817.photobucket.com/albums/zz92/tomw1123/20121118_193453.jpg)
![[Image: 20121118_193437.jpg]](http://i817.photobucket.com/albums/zz92/tomw1123/20121118_193437.jpg)
![[Image: 20121118_190202.jpg]](http://i817.photobucket.com/albums/zz92/tomw1123/20121118_190202.jpg)
Cartridge is completely f*cked all the way round the coldside. Cannot describe how raged i am.
How NOT to clock a td04 :'(
![]() ![]() ![]() Cartridge is completely f*cked all the way round the coldside. Cannot describe how raged i am.
18-11-2012, 08:19 PM
The TD04 is not fun to clock at all!
18-11-2012, 08:21 PM
'the f*ck did you manage that? You got hands like hagrid or something
18-11-2012, 08:23 PM
With a mallet....
In all seriousness i was speaking to Darren this afternoon about this stuff and he said clamp it up in the vice and just tap it round and it'll go. Oh its gone lol
18-11-2012, 08:30 PM
WTF tom? I said tap it with a rubber hammer, how hard did you hit it??!!
| #DervMafia | ![]()
18-11-2012, 08:33 PM
Whats clocking it?
In all seriousness i could hit it alot harder if thats what i was going for :/
(18-11-2012, 08:33 PM)Tyronnster Wrote: Whats clocking it? Rotating the hot and coldside so they line up with the manifold and where ever you want the pressureised bit pointed lol
18-11-2012, 08:38 PM
18-11-2012, 08:45 PM
Holy moly!
18-11-2012, 08:52 PM
I wish i could see where youve gone wrong :p
..has no clue about td04 /selfslap
18-11-2012, 10:44 PM
Will still work tho, as long as its caught somewhere will still hold the comp on..
18-11-2012, 11:10 PM
Its fractured right the way round and theres a bit of seal stuck in there aswell :/ I think its pretty f*cked
18-11-2012, 11:17 PM
My TD04 had a locator lug on both sides of the cartraige so i have to take the housing off and redrill holes for it. the housing one anyway but i ground it off the hotside.
TD04 11mm Sedan, now 2.1 vnt
Sedan Project http://306oc.co.uk/forum/thread-5763.html Provence Dturbo Dead Blaze 1.6 Dead China 5dr '6 Death by cambelt failure Matt White HDI estate Death by wiring Sedan Dturbo aka triggers broom Diablo estate Dturbo Living dead
19-11-2012, 06:54 PM
lol dont scrap it, even if you just epoxy the hell out of it, I would still put it on a car to save buying another one! Its on a flush flange its not like its loose is it, other than rotating round am I right?
19-11-2012, 08:21 PM
Surely that bit of oil seal pinched in there means it would leak oil everywhere and be f*cked? I think im going to have to buy a replacement lol its still not loose i cant turn it by hand
19-11-2012, 10:46 PM
Please tell me you havent tried tapping it with the circlip in place? Bit of a tip with these split the hotside first then you can get more access and can tap it much more easily, iv done 3 td04's and never seen this
20-11-2012, 05:05 PM
More pictures of the comic damage to come, got it all apart now
20-11-2012, 06:05 PM
(This post was last modified: 20-11-2012, 06:15 PM by darrenjlobb.)
To be fair, could probs fix that with the welder, would oinly need some spots around the edge and it would be perfectly useable again given you havent bent the blades to badly
Dump the turbo on my bench next time your passing mate, and ill see what I can do, | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
| #DervMafia | ![]()
20-11-2012, 07:36 PM
Gutted for ya bud, at least they cheap enough get it round to darren and get it in and look for another in mean time
20-11-2012, 07:38 PM
Right here goes. Need a new oil seal but i reckon we could be crafty with a welder and fix it.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Gave it a wipe over with a rag but it looks really good to me! Except the broke bit lol ![]()
20-11-2012, 08:01 PM
looks ok, just run a tig welder round it
20-11-2012, 08:19 PM
(20-11-2012, 08:01 PM)Daniel306 Wrote: looks ok, just run a tig welder round it I think thats the plan! We shall see tomorrow ;D
20-11-2012, 08:22 PM
Youve tried tappin it round with the housing attatched, when we say give it a tap to free it we mean with the circlip released as it has a locating pin and wont budge hence why its dont what its done pal hope you can salvage something from it
20-11-2012, 08:54 PM
Im going to get the welder out on it tomorrow!
| #DervMafia | ![]()
20-11-2012, 09:04 PM
(20-11-2012, 08:22 PM)CJ_Derv Wrote: Youve tried tappin it round with the housing attatched, when we say give it a tap to free it we mean with the circlip released as it has a locating pin and wont budge hence why its dont what its done pal hope you can salvage something from it Darren said it would go without removing the clip, he must of forgot about the lug and i obviously dont know any better lol look what i done to it! This is all part of the learning curve! Wouldnt be fun if it was easy ![]()
20-11-2012, 09:22 PM
I basically said to tom that I always spin mine by just tapping it lightly with a rubber mallet, and they normally go fairly easily with clip in, not thinking that this was a totall stocxk turbo / had never been apart before ! That said, the word tapping was used, not lamping lol!!Heavy hand me thinks
![]() | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
| #DervMafia | ![]()
20-11-2012, 09:27 PM
At least it should be able to be fixed, i know a thing or too about being heavy handed
21-11-2012, 06:41 PM
Had a quick go at repairing this for Tom this afternoon,
Sadly ive also noticed one of the turbine blades has a small chip in it, so its not ideal, to be fair it would most likely be fine, as things normally are, but never going to be perfect again, but made the best of whats left anyway. ![]() | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
| #DervMafia | ![]() |
