Lucas pump bung - temp fix possibilties - FIXED!
So ive found the source of my fuel leak, and its the bung on the Lucas pump that you have to take off to get to the max fuel screw (poxy lucas pumps! grrr). Im HOPING that the local pug dealer will have one in stock (if anyones got service box, a rough price would be appreciated), but ive got to get home yet tonight.
One option is beg my mum to lend me her Micra for the night, but i dont think she was entirely convinced with that idea, so im trying to find some sort of temporary fix that will get me home, and then to work in the morning.
My bro has suggested this:
[Image: 2012-11-18171031.jpg]
...but it mentions that it shouldnt be used anywhere that it will be in constant contact with petrol. Would this also apply to diesel? And how easy would it then be to get the old bung off to put the new one in tomorrow (assuming i can actually get one)?
Any suggestions/help appreciated! Big Grin
You're gonna bin the lucas right?
If so, just liquid metal on the outside? might stop it enough.
Failing that, gaffer tape?
liquid metal, or that stuff might work. just degrease beforehand
Well yeah, the pump is at a point where im happy with the tune, so to all intents and purposes, i could weld the damn thing shut. I have got my bosch pump, but no lines or injectors at the moment, so its not like i can just get the conversion done. Which is a PITA. I want my bosch on.
Funnily enough, my missus suggested gaffa tape as well! lol
where would i get liquid metal?
/n00bquestion
any motor factors that's decent failing that halfords lol
My mum has suggested using clingfilm in a PTFE tape style, im not sure that sounds like a good plan?
(18-11-2012, 05:33 PM)WiNgNuTz Wrote: My mum has suggested using clingfilm in a PTFE tape style, im not sure that sounds like a good plan?
Worth a go, right??
im willing to try just about anything at the moment! lol
probably just need to replace the o ring, no? so cling film might work, couple of folds of it
put the lid in a johnny? bit thicker than clingfilm...
ah good shout, you are small enough to fit in a lucas pump!
(18-11-2012, 05:35 PM)Jonny81191 Wrote: put the lid in a johnny? bit thicker than clingfilm...
This is a full-on bodgetastic thread now. lmao
you want to bodge a leak, and me and samass are online.
Of course it's gonna be bodgetastic!
What more could i ask for, eh? lol
Helpful posts are overated anyway Wink
I was being serious lol
what about araldite? or a hot glue gun?
Its all good, as said, i need a quick bodge, and youve helped out immensely! Big Grin
so, which one you gunna try? lol
Well i havent got any johnnys to hand, and i dont think clingfilm will hold up to much in the way of heat, so i think im gonna give the loctite a go.
that might work. maybe wind the cap out a bit and fill the gap? giggity?
epoxy putty?
(18-11-2012, 05:52 PM)Kwik Wrote: epoxy putty?
Havent got any of that to hand either. Seriously limited on supplies, and nowheres open to get anything either. Gotta work with what ive got at the moment. Undecided
rubber band instead of the o ring?
rubber band is a good idea. the garden tap is sealed like that as o rings wouldn't work lol
is it just not sealing or have you butchered it?
its been notched around the edge, where ive opened the pump to adjust the max fuel a few times, i can only assume one of the notches has gone too deep, or the o ring if fudged.
Rubber band does sound like a good plan actually.
blu tack?
tried that....failed.
i'd go for the cling film idea personally.
Well, between them, my mum and samass came up with the goods in the end (inb4giggidy). I got the bung off, wrapped some cling film around it in a PTFE tape fashion, then put a small rubber band over the top of that, and its sealed it a treat! Absolutely bone-dry now.....stationary anyway. Ive got to go and get the missus so we can go home now, so ill check when im home and make sure its still dry then.
  Lucas pump cap carlukepeugeot 7 8,103 19-11-2020, 12:14 PM
Last Post: johnny625
  Lucas pump timing probe issues weka 0 2,642 21-03-2019, 08:39 PM
Last Post: weka
  Need help d turbo lucas pump. Djbeny4477 1 3,195 21-10-2018, 05:15 PM
