17-11-2012, 01:34 PM
(This post was last modified: 17-11-2012, 03:50 PM by rocker8742.)
How does it come out of the caliper ? As i can't shift this
![[Image: 2012-11-17133035.jpg]](http://i1133.photobucket.com/albums/m598/rocker8742/2012-11-17133035.jpg)
Tbh im probably just being thick
Stuck handbrake cable
![]() Tbh im probably just being thick
17-11-2012, 01:53 PM
It's an interference fit bud get a small spanner 6mm or so, pull the rubber back put the spanner on the end metal part, and tap it with a hammer
17-11-2012, 02:55 PM
I ended up cutting mine out with an angle grinder as the f*ckers wouldn't come out. Calipers were already f*cked anyway as both had snapped nipples.
17-11-2012, 03:22 PM
Undo behind the handbrake in the car. Will become loose at the back.
On the 306 waiting list.
| handbrake cable | 306pc | 2 | 2,444 |
07-01-2015, 10:55 PM Last Post: 306pc |
| Handbrake cable | W1ll | 7 | 5,144 |
28-04-2013, 03:07 PM Last Post: W1ll |
| replacing rear calipers/ using existing handbrake cable | Lew_Derv_T | 4 | 4,256 |
13-03-2013, 12:52 AM Last Post: Lew_Derv_T |
