replacing rear calipers/ using existing handbrake cable
as above im replacing my rear driver side caliper, when removing shall i slacken the cable near the backbox?
just looking for a step by step guide on what i need to do and how much appreciated guys. i pretty much now how to replace and bleeding etc just a bit stuck on the handbrake cable.
Handbrake cable just a case of removing the centre console piece that goes around the gearstick and handbrake which is a case of 2 10mm nuts and 2torx screws then slacken the handbrake cable off with a deep 13mm socket and then it should be a case of unhook the cable off the caliper and then if your lucky the cable should come out of the hole it goes through on the caliper if not use another socket around the same size and tap the outer casing towards the front of the car and the rest is straight forward!
[Image: ForumSignature.jpg]
He's not replacing the handbrake cable, he intends to reuse it. It uses a splined taper to lock in the caliper, unhook the end then use a punch and hammer to knock it out the caliper.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
(11-03-2013, 09:09 PM)C2K Wrote: He's not replacing the handbrake cable, he intends to reuse it. It uses a splined taper to lock in the caliper, unhook the end then use a punch and hammer to knock it out the caliper.
I know that just telling him how to get it away from the caliper ThumbsUp
Cheers guys so its a splined washer on the caliper arm where the handbrake cable goes through? Just wd and a punch and hammer? How do i get the new caliper on the spline? Use the old one? Etc etc cheers for the help
  Rear brake calipers Welshy_Pete 2 2,910 19-03-2017, 07:17 PM
  Any tips for undoing rear bleed nipples on calipers? Tom85 18 8,364 27-06-2016, 07:39 PM
  Removing broken bleen nipple/How many types of rear calipers? Iaitoo 16 8,024 31-03-2016, 02:25 PM
Last Post: pug306driver
