wiring diagram
i could use a wiring diagram for my 1.9td that sits on peugeot expert. Problem is lack of voltage in shut off valves wires, only 9 volts and thats not enought to open the valve. And id like to know what are the other wires in the same connector on the side of the pump, 4 of them. My own guess is 2 is for shut off valve and maybe the other 2 has something to do with immobilizer.
if you converted have to wire up the lives together to top of stop solinoid or it won't work
everything is like it came from factory but theres only 9 volts in wires that go on shut off valve and there should be 12 volts to work correctly. the wiring diagram would give me clue where that wire comes from, if theres fuses relays etc. stuff that can has bad connection.
umm somthing tells me you can get different voltage shutoff valves Wink
that sounds like fixing a tyre with bubblegum. and theres that immobilizer thing covering that shut off valve.
  wiring diagram craig-dodd 5 3,271 26-10-2012, 09:52 AM
Last Post: Tom
