*106* Passenger strut moving inwards.
Hey guys move this thread if you want wasn't sure where to put it.
Pug 106 Petrol 1.4
Passenger side strut when driving makes a horrendous knocking noise sounds like up and down as well as side to side.
Just had it on the drive i can move the wheel inwards towards the drivers side quite drastically but when its jacked up its even worse. The model doesn't have drop links I have checked the bottom arm and the TRE am I correct in guessing its the top mount?
Sister in law has said its been clunking on full lock for 12 months so i presume the top mount bearings have finally collapsed?
Thanks for any input.
Richie.
My top mounts have collapsed, just feels rough and non PAS...
Sounds like ball joint to me, I've even known them fall apart and pull the shaft out and the wheel away from the car.
If not, checked the wheel bearing?
Id say drop link
How much movement is it? Top mount could be at fault
Top mount or lower ball joint
(13-11-2012, 07:20 PM)puglove Wrote: Id say drop link
Doesn't Have Drop Links.
(13-11-2012, 07:22 PM)Matt Wrote: How much movement is it? Top mount could be at fault
A very large amount of movement. 20cm +
20cm?! Don't drive the bloody thing. I'd be checking that the top mount is still actually connected and that the balljoint hasn't snapped
Christ! Yeah don't drive that shit, something must clearly be disconnected entirely!
Yeah its definitely something to do with the top mount. It looks dodgy to start with as the main strut bolt has two nuts on!
I'd definatley have that off then!
Strip it out either your ball joint is knackered or the top mount is completely shot
cant see a top mount cauing that much movement? i thought if anything that would only move like 5cm max?
only thing that would cause that amount of movement was if something had snapped
easy way to tell top mount failure even if you dont know cars
jack the car up on pass front in this case and axle stand it on the subframe
get someone to look at the top mount while you move the wheel and see if the central nut/strut moves
hope this helps
oh and massive movement can be more than one thing, starts as one thing damages others and gets worse
i say just start stripping it all back, it'll be pretty apparant whats f*cked if its moving 20cm...
Fixed it for her, top mount bearing had collapsed and bottom ball joint was loosey goosey.
The shocks on 106/saxo also get a bit of play in them. Similar movement to knackered topmount / lower BJ.
oh, and when there's play in the shocks there's usually a knock when manouvering into parking spaces and low speed turning lock 2 lock
[Image: KrisB-new-Logo11.gif]
  Rear brake pad moving. Marcus1991 2 1,568 26-05-2014, 08:57 PM
Last Post: Marcus1991
