12-11-2012, 05:41 PM
I am led to believe there is no diffence in hubs apart from the size of the bottom ball joint is this true????
hubs
12-11-2012, 05:42 PM
yep, thats the only different
12-11-2012, 05:46 PM
12-11-2012, 05:48 PM
ah yeah good point chris, didnt think of that
smokey, make sure you're getting the right size joint, its possible that you've been getting the smaller size and its ovalling the hub Member of the 99% warning or you're nothing club
12-11-2012, 05:51 PM
(12-11-2012, 05:48 PM)samass Wrote: ah yeah good point chris, didnt think of that Thats exactley wat keeps happening I almost scrapped it this morning I'm wipeing scrappys out of nearside hubs. Am I best off getting a hub and taking it to gsf and getting one that's off the new one
12-11-2012, 05:52 PM
yep, deffo. makes sure its the right one that way
12-11-2012, 06:50 PM
Have you tryed changing the ball joint? Get a hub from a phase 3 then buy an 18mm new ball joint. If it does it again there is somthing els at fault.
What phase/engine 306 have you got?
12-11-2012, 07:04 PM
12-11-2012, 07:17 PM
more than likely the 18mm ones then, that'll be the cause
12-11-2012, 07:27 PM
As said then change the ball joint then. If it does it again then you got an issue eles where
13-11-2012, 12:24 PM
Hdi on a v with bottom joint should fit????
13-11-2012, 12:27 PM
in theory. unfortunately its peugeot, so difficult to say with certainty. but, it'll be more likely to be an 18mm ball joint than 16mm.
13-11-2012, 01:14 PM
13-11-2012, 01:30 PM
Nope, not at all. As long as the hub and ball joint match, its fine. I used to have 18 on the left and 16 on the right, made no odds
13-11-2012, 04:02 PM
Like a glove fits perfect wonder how long this one will last
406 HUBS | thethorne | 45 | 9,791 |
30-11-2016, 09:13 AM Last Post: Janne L |
XUD hubs on Hdi | ct-hdi | 2 | 1,153 |
09-03-2015, 07:15 AM Last Post: Dum-Dum |
hubs | cluskie | 6 | 1,796 |
14-09-2014, 03:47 PM Last Post: 306gtiparts |
