Leak from Sunroof or Aerial
Anyone know which it might be?
Am I right in thinking there is a seal under the aerial that could be gone?
When it rains heavily the inside gets quite wet around the light panel.
wip the light out and have a look mate i think there is a rubber seal between the aerial and the roof
^^ what he said
silicone the shit out of the fucker
Open the sunroof and clear the drains in the corners - they can sometimes get clogged up
Ah lovely, not better to replace the seal or do they perish quite easily? I have silicone if its gonna be just as good..
silicone would work just as well
(12-11-2012, 04:46 PM)maxlee Wrote: wip the light out and have a look mate i think there is a rubber seal between the aerial and the roof
This.
Its only a couple of Torx screws to get the light unit out, and a 10mm socket/spanner iirc to undo the aerial. Simples.
Edit- - Just realised youve got a sunroof to think about as well. Skim reading ftl. Sad
Ok cheers guys.
Silicones the sh!t out of it and seems to of solved the problem.
Rep given. (:
When mine went I tiger sealed the fucker. Fix it an then leaked a month later. Sorted with about 1/4 of the tube of silicone in the end haha
(16-11-2012, 05:16 PM)Matt Wrote: When mine went I tiger sealed the fucker. Fix it an then leaked a month later. Sorted with about 1/4 of the tube of silicone in the end haha
Lol, think I might reinforce it with a second helping, current weather isn't helping at all!
  Do I need a new aerial for DAB radio? DonGonzo 1 2,780 15-04-2022, 07:29 PM
Last Post: Mighty306
  306 Cab aerial repair Aussie306Cab 0 2,698 19-01-2021, 03:40 AM
Last Post: Aussie306Cab
  Sunroof adjustment Betty 0 2,155 31-05-2018, 11:09 PM
Last Post: Betty
