ph1 xud no ignition lights
did have a search before i started this topic
i have a ph1 D trubo put a good battery on it to day and no ignition just a click from a relay under the dash.
it dose have a keycode pad in it never needed to use it before but green light and red light is just on i read that this could be a bad earth?
hand brake light works dash lights head lights etc just no ignition lights / glow plug light. and dosen't turn over Confused
i'm going to have a good check of the earths live wires and fuses later just thought i would ask incase some one has had the same problem and could point my in the right place to look 1st Blush
sounds like keypad has shorted. just trying to remember how to bypass it without cutting off the shield on the pump........
Need to by-pass the keypad, I did mine on my old D Turbo but I can't remember how.
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
it normally is while it is running unplug it but he can't get it running lol
  Instrument lights, dash lights not working boggs 3 4,302 26-01-2016, 09:34 PM
Last Post: DeeTurbo
  ignition lights staying on / wont turn off sweeney1987 9 4,473 25-01-2015, 08:31 PM
Last Post: sweeney1987
Star ignition lights are on without a key in the switch.. wont start :( lamkov1991 10 5,382 01-12-2014, 07:06 PM
Last Post: lamkov1991
