8J ET0 fitment advice required
hi guys spotted these on ebay:
http://www.ebay.co.uk/itm/160915868618?s...1423.l2649
safe to say i badly want them, problem is the centre bore is smaller than 65.1mm but does everything else seem okay?
whats your opinions on making these fit?
cheers
[Image: 20gh7o0.jpg]
What size is the center bore?
Assuming they are deffinately 4x108 and not 4x100, then they look almost exactly 65.1mm to me.
Centre bore will be 63mm
JJ0063 was after them too and he emailed the guy and said its smaller, dont know what it is though. currently trying to find out
assuming they are 63mm like ford centre bore, whats it gonna take to make them fit? i seen some spacers on ebay that reduce the centre bore but they were 120 quid!
anyone got any ideas? these end tomorrow lol
I'm sure you could get the centers bored out like 2mm by a local engineering company, would probably only be ~£10 a wheel.
cheers mate its more wondering if that would cause any issues with stability? and anyone any experience on how these will sit being 8j et0, any problems with inner clearance etc
Running 8j et -20 on my estate with 100mm ish drop, took alot of archwork and had to cut and re do tge door shut. Also running 185/45 tyres. Depends on how low your are
And for re doing the centre bore i have a mare that may be able to do it for you, i know he redrilled my mates wellers.
Shocked P-bush advice required devils_fuel 16 11,082 21-07-2013, 08:37 AM
Last Post: Niall
  Wheel fitment HELP! and suspension advice maz-306-xs 6 3,914 30-08-2012, 08:55 PM
Last Post: maz-306-xs
  Parts-advice required for a DT devils_fuel 24 11,952 16-04-2012, 11:29 AM
Last Post: devils_fuel
