06-11-2012, 09:28 PM
Is there any advantage to swapping from phase 2 to phase 3 headlights other than looks plus what is needed to swap over besides the headlights
Headlights
06-11-2012, 09:37 PM
You should also swap to a twin optic stalk or modify your original stock, i think that the Ph3 lights have better light output
06-11-2012, 09:47 PM
Ok will they just plug in Besides that what bulbs are in the p3 headlights
06-11-2012, 10:02 PM
They are a direct replacement for Ph2 lights, and they take H7 bulbs
06-11-2012, 10:13 PM
the only thing you'll want to keep from your ph2 lights will be the adjusters on the back, they should just twist off the ph2 lights, then twist back on to the ph3's, only cos Peugeot changed the connectors between phases.
08-11-2012, 08:32 PM
(06-11-2012, 10:13 PM)WiNgNuTz Wrote: the only thing you'll want to keep from your ph2 lights will be the adjusters on the back, they should just twist off the ph2 lights, then twist back on to the ph3's, only cos Peugeot changed the connectors between phases. They can be a bit of a faf to clip back in this way. What I did was clip of the electrical gubbins from the back of the motor and swap this bit over instead.
08-11-2012, 11:16 PM
How do you mean ??
11-11-2012, 12:33 PM
11-11-2012, 03:13 PM
Ok will do thanks
14-11-2012, 08:00 PM
i unclipped the adjusters and plugged them in the phase 3 ones.
Light output is far greater and make the front look way younger lol
