Electric Window Reg question
My drivers side window reg has broken. Took it apart yesterday and the pulley/cog doesnt seem to be able to pull the two cables up/down. I also noticed that one cable is a bit fraid.
Is this repairable or do i need to replace the whole mechanism?
Whole mechanism is the easiest method - bish bash bosh, job jobbed!
(02-11-2012, 10:41 AM)ash240970 Wrote: Whole mechanism is the easiest method - bish bash bosh, job jobbed!
thought that was going to be the case. the thing is the motor is fine and the regs ive seen on ebay are lots of money
also are the different phases interchangable? i have a ph 2 but will a ph1/3 fit?
All 3dr ones fit 3drs, same goes for 5dr ones.
Can do you a 3dr one for £20 at ace? or post it for £27.50
[Image: sig.jpg]
(02-11-2012, 11:11 AM)Chris Wrote: All 3dr ones fit 3drs, same goes for 5dr ones.
i need it asap. bodged a bit of wood with some duct tape in the the door it self to keep it up! how much from pug?
Price from Pug = arse ra*e :0
And as said before 3 door fits 3 door and likewise for 5doors but depending on phase the electrical connecting plug varies and some are parts bin specials.
A picture of the type of plug you have will benefit your search unless you cut and rejoin the wires which is a 5 min job.
  Electric window switch help Aaron _d95 3 5,486 08-02-2020, 11:47 AM
Last Post: arronnjackson
  Removal of driver's side electric window switch balkan_bozo 10 8,830 04-07-2018, 03:03 PM
Last Post: pug306driver
  off side Electric window and door not working bluebenz1 1 3,304 01-05-2018, 10:07 AM
