Gti6 axle on a estate
I've got a gti6 axle will it fit on a estate? Thanks
Team Doesn't own a 306
It will, it's what I have. The torsion bars are a bit on the soft side for it though.
Yes :p
Hmm why they a bit soft mate? Thought they had thick torsion bars?
No estates have bigger TBs and bigger ARBs than a gti to deal with the weight difference. What phase is the estate you have?
Late phase 3 HDI's have 21mm torsion bars, GTI6's have 20mm. They're ok, just too soft for my liking. Then again I have my own reasons why they're too soft...
Ph2 meridian, may not bother fitting it then
A phase 2 meridian estate will have 20mm tb's the same as the gti only some late phase3 estated had 21mm so the gti beam will be fine Smile
Don't know if its worth the hassle then may weigh the beam in with the car
the spec on servicebox for my estate says
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 20
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 22
the TB'S for the estate are listed as
DW10 RPO< 08882 20mm right 5150 59 left 5150 56
DW10 RPO> 08883 21mm right 5150 82 left 5150 81
the rear ARB listed for the estate are
18mm 5170 81
19mm 5170 80
20mm 5170 82
21mm 5170 84
Dont think its worth me changing it then really
Deffo isnt worth the hassel
Prefer drum anyway! Cheers lads
  B4/Eibach with GTI6 Rear Axle MY95 3 2,766 24-01-2017, 10:49 PM
Last Post: MY95
  GTi6. beam bearings and stub axle measurements Ben_w 14 7,948 01-06-2015, 05:22 PM
Last Post: Ben_w
  1998 gti6 Axle on 2001 HDI boggs 4 2,894 02-10-2014, 09:40 AM
Last Post: Toms306
