Would you buy this dented alloy wheel?
I have the opportunity to buy a set of second-hand alloy wheels.
One of them has two small dents on the inside of the rim:
[Image: T2eC16FHJF8E9nnC6MKBQMO4mc-60_58.jpg]
[Image: KGrHqNHJCkEQmTK9zqBQMO3jkWDQ60_58.jpg]
Would you buy them in this condition?
Will the dents be a problem?
if they were cheap enough yes
id have ago at beating the dent out if they were the alloys i really wanted
if i failed
id sell the tyres on and scrap the alloys to get my money back
That rim is pretty bad tbh as cully said though you could have a go at beating it out. If not you could try and biy a single to replace it
Ive straightened worse Wink
lump hammer and a block of wood leave the tyre on as it helps not to over stress the rim
be warned though the alloy will become porous if you work is to much, leading to slow punctures
Wouldn't even bother knocking it out unless it affects the seating of the tyre. Looks fine.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Thanks for the advice, guys Smile
Nowt wrong with that, I've balanced worse lol
There are plenty of companies now that specialise in straightening alloy wheels that are cheap enough
Now only a has been!!
www.autorite-sport.co.uk
I have balanced far worse than that that's a very mild dent TBH
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
If put the two bent wheels on the back i dare say you wouldn't even notice
Would I buy it? No. Should you buy it? Yeah why not. Big Grin
Depending how bad the dent is though, you can feel it on the back, I had a dented wheel with no wieghts at all on the back once (was a swallow btw) and could feel it shaking the whole car! Not a problem, I just sold it on another car. Big Grin
  Alloy wheel stamp. Pugwash 5 4,403 05-06-2018, 03:15 PM
Last Post: Pugwash
  Alloy Wheel Bolts rdstars 2 2,232 16-03-2017, 05:01 PM
Last Post: rdstars
  c5 steel/alloy wheel bolts Poodle 8 4,826 20-04-2015, 08:42 PM
