17-10-2012, 06:19 PM
hi just wandering what welding the wastegate would do to my d turbo, (pro's cons) thanks.
welding the wastegate ?
Pro's -
Booost, Cons - Lack of control of said boost. Lol I'm also interested in the information here.
On the 306 waiting list.
17-10-2012, 06:25 PM
Basically as above lol, mine is welded shut, if its a standard turbo don't bother IMO, welded gates need to be controlled by the amount of fuel as there is no wastegate to do that if you weld it up
18-10-2012, 06:54 AM
In reality you will make more power with a welded gate, but its a horrendously inefficient way of producing more power, completely the wrong way to go about turbocharger tuning, but its free, and it works
its just in the XUD applications the engines/turbos are normally strong enough to withstand the abuse/heat caused by this so most people just drash on..
18-10-2012, 08:06 AM
I am wondering about this for the future setup of 11mm pump and TD04L-19t hybrid, Although im worried about spacing issues once its got a bigger inlet housing than the 13t and 15g and then will have a actuator on. i am also wondering what the turbo would be boosting with a welded gate and biggish pump
Im currently ruinning TD04 with welded gate and think the 9mm may have some more to go yet and runnin 30psi atm CJ
18-10-2012, 08:18 AM
I'm running a welded gate K04. It's ok so far, but I know it's not going to last at 30psi so I'll be building another with a wastegate on.
Stage 2 XUD Sedan
| T2 wastegate arm | AdamInNi | 4 | 3,326 |
02-09-2014, 11:02 AM Last Post: Dave |
| welded wastegate help | daveylennon93 | 16 | 9,078 |
31-07-2014, 04:44 PM Last Post: Dum-Dum |
| T2 wastegate | pbell283 | 20 | 11,691 |
06-06-2014, 09:59 AM Last Post: toseland |
