01-09-2014, 03:33 PM
Anybody any trick to get the waste gate arm of a T2 back onto the pin after screwing it? Seems to be a right nightmare!
T2 wastegate arm
01-09-2014, 04:20 PM
I had a bit of a struggle years ago, included a pry bar and a smashed finger lol, easier to get a mbc
01-09-2014, 04:50 PM
As said, just stick an MBC on it. Makes turning boost up so much easier.
As for getting the arm back on, if you pull it a little (from the actuator) you should be able to get it onto the wastegate pin.
3 x Peugeot owner.
1996 106. 1996 306 D Turbo S. 1994 Mercedes Benz 320E. 1997 306 GLX. Subscribe! - https://www.youtube.com/user/TheADKJD/videos
01-09-2014, 05:08 PM
Only trouble with not tightening the wastegate arm is you will probably get slight wastegate creep when running high boost pressures with an mbc
| welded wastegate help | daveylennon93 | 16 | 9,439 |
31-07-2014, 04:44 PM Last Post: Dum-Dum |
| T2 wastegate | pbell283 | 20 | 12,146 |
06-06-2014, 09:59 AM Last Post: toseland |
| Wastegate creep? | ADV_93 | 3 | 3,538 |
14-09-2013, 04:15 PM Last Post: ste91 |
