Threads: 189
10
Car Model/Spec: E39 ACS 535i
Right picked up a hdi for cheaps yesterday as it was advertised as running but cutting out.
When I got there the car wouldnt start, as I'd traveled 120 miles for it with a trailer I bought it anyway, as its worth more in parts than paid.
Had a quick go over it today.
There is no power to the lift pump (the pumps fine though) and the fuel gauge doesnt work. The only power at the lift pump is the small gray wire presumably for the fuel gauge power.
I've powered the pump remotely and it still doesnt start.
Items changed
About 10 fuses replaced/put back, All other fuses checked
Brown relay behind the battery.
Tested the ECU off my car.
Fuel cut off thing with the red top.
Need to test the green relays behind the battery also, but cant see these being faulty.
Anyone got any ideas?
Threads: 189
10
05-10-2012, 03:08 PM
(This post was last modified: 05-10-2012, 03:09 PM by Chris.)
Texted
Alos its a y plates so a 592 ecu
Threads: 465
114
Car Model/Spec: Vauxhall
double relay behind the battery remove it and check the plug socket and relay pins for burnt bits
Threads: 189
10
Checked them and there fine
Threads: 18
Car Model/Spec: Black ph2.5 Dturbo
didnt realize you went and got it lol
Threads: 62
10
Can you read the Ecu? May have been shorted.
HDi Owner for 200k/9 years
Threads: 189
10
Yea read the codes that were on it fine.
Threads: 62
10
What's going down with the immobiliser? Does it crank and not catch?
Threads: 183
20
Given 8 thank(s) in 8 post(s)
If its moonstone and had a recent clutch change... Don't bother! Haha. :p
Have you tried immobiliser? But I suppose that wouldn't explain why it was cutting out. Sound defferntly fuel related. Get someone to prime it on the key and listen out for air leakage.
Check injectors for fuel and power. Check filter housing pipes if they're getting fuel through as we'll when priming.
Cam or crank sensors? How does the fuel pressure look?
