headgasket
so it seems the headgasket has gone again after only 6k
pressuring the coolant system like a good 'un - think taking off the cap and it shooting 6 foot into the air.
no oil leak this time
not happy Sad
What spec is the tune?
So this is the black Zx
25psi mostly on a k14 with fuel upped to match, switched to a slightly bigger turbo but done less than 1k on that still at <25psi
Started running a little more static advance last week
11mm pump went on today :/
So really not wild power, say 120ish - might be running a little more now but not much
It's not overheating
could it not be the thermostat not opening properly? sam was getting similar symptoms, did the thermostat at all is good...
Stealth 3door Dturbo - In progress
http://sphotos-d.ak.fbcdn.net/hphotos-ak...6076_n.jpg
It may be worth checking stat ive had similar problem in past
[Image: J5hxCcC.jpg]
Nah it's not the stat, tried that.
Nipped up the head bolts, not quite as bad now, just a little hiss after leaving overnight.
  MLS headgasket enquiries. 205dtub 14 9,072 18-02-2015, 11:56 PM
Last Post: vinny
  Headgasket failure? AdamInNi 3 3,011 31-08-2014, 10:16 PM
Last Post: AdamInNi
  headgasket ? Teddy 6 4,522 23-04-2014, 02:57 PM
Last Post: Paul Baldwin
