clutch gearbox problem help!!!
#31
You say the clutch was already on the flywheel yeah, you didnt touch it all? Did you check it over though?
Had a similar problem when I was at Ford, one of the clutch plate springs had popped out and was catching all the time so was hard to get into gear and when it was in gear with the clutch down would still try and drive.
nope never touched it atall or looked at it never though there was ne need to tbh
emm yea that sounds very familer to whats happening with mine may take the box back off and see if cant see anything i might just stick my own clutch on and see what happens only thing is its a near new valeo clutch on it
[Image: 306sig.jpg]
The one we done was on a nearly new van, just a faulty clutch had been put on, wasnt old or anything. Looked fine even after the box had been removed, but was very obvious when the pressure plate came off what was wrong with it.
Good luck. Wink Sound like you need it lol!
emmmm does sound the same ah well ill just wip the box off and have a nosey to see what i can see
i need all the luck i can get lol
[Image: 306sig.jpg]
i'm getting them just cause they will last way longer then stock and i'm deffo keeping project t lol
might just order a set for the craic im sure they would be a good job
[Image: 306sig.jpg]
  Clutch problem MarkTD 15 5,632 22-04-2018, 02:04 AM
Last Post: Dave
  clutch 'problem' carlukepeugeot 1 1,259 26-01-2017, 04:08 PM
Last Post: ADV_93
  Clutch and/or Gearbox change 205 XUD silverzx 8 5,124 16-02-2013, 07:21 PM
Last Post: silverzx
