Water in door seal
My passenger door seal keeps filling up with water and then leaking inside but I've got no idea how its getting in, anyone had this before? Got any ideas how to stop it?
[Image: signiture.jpg]
there must be a hole somewhere, mine has one and its annoying, filling up my footwell :/
Drill a hole on the outside for it to leak out.
There is no hole, it's just the volume of water over spilling over the seal into the car.
im gunna do this in 5 mins and post results next time it rains Big Grin
also where were you off to today mark?
I thought about that but wanted to find the root of the problem and fix that, is weird as I can't seem to see any wet parts round the top all appears to be in good condition no rips
all of mine have done this in really heavy rain. if you have the option, park facing up hill, seems to be a good temporary fix
(02-10-2012, 08:16 PM)Jonny81191 Wrote: all of mine have done this in really heavy rain. if you have the option, park facing up hill, seems to be a good temporary fix
that doesnt work for me Sad
Off to the job centre. HIDs look good.
Water gets in the seals at the top and then follows it to the bottom
Hmm can't see anywhere guess will drill a small hole in the front and the back so it'll just drain through
Just stick a Stanley blade along the bottom
i have exact same problem,i found if i park with the car slightley tilting to the passenger side i have no leaks but if the car is tilting to the drivers side it pours in and fills right up...fookin pain in the arse.
The water runs down the middle of the seal the collects under the door and pools, it is spills over just below the speakers in the front doors. Just cut or drill a hole here to the outside and it will be fine
(14-10-2012, 07:42 PM)Pompey306mark Wrote: The water runs down the middle of the seal the collects under the door and pools, it is spills over just below the speakers in the front doors. Just cut or drill a hole here to the outside and it will be fine
thats right yeh..will drill it then,5mm hole should be enough ?
if i run my finger along the rubber seal it spits water out Speechless
Exactly what mine was doing so cut a small cross slit under each hole seems to be OK now
Wish i'd read this thread before.. been doing it on the drivers side of my 6' and was a fair amount of water in there this morn lol
I found a 3 inch puddle in my passenger side which gave me the incentive to do fix it! had to get a mop and bucket out!!
on the plus side it is nice and clean in there now
  Door seal leaking, cant figure it out? Charlie0 16 10,672 24-09-2018, 03:51 PM
Last Post: RetroPug
  Water coming in through door Mighty306 6 3,835 22-08-2017, 07:15 PM
Last Post: DeeTurbo
  leak on pasaanger door window seal L16rye 6 5,696 09-11-2016, 11:57 PM
Last Post: L16rye
