URGENT - HDi Aux Belt Replacement!!!!!!!!
Hi guys,
Need to replace the aux belt within the next hour, wheel and inner arch liner is off and.......
Now heres the complicated bit, haynes is crap as it shows the engine out of the car where theres plenty of space. Theres no space at all in reality!! Sad
I've found the tensioner with a 15mm nut....is that the one I push towards to the bulkhead? Then what, does it stay there or will it spring back?? Then just slip the old belt off and new one on??
HELP!! Huh
Tom
That's the one get 15mm spanner on it and another on that spanner. It springs back. Ill sort a picture of where belt runs.
Ok, from the top or underneath?
From the top is easier.
DONE!! Big Grin Cheers guys. Got my stepdad to hold the tensioner while I took off then fed the belt back though. Smile
yay Smile
already told you this 3 days ago!
  Cost of Timing Belt and Water Pump Replacement? JTaylor2005 7 5,445 12-02-2018, 03:29 PM
Last Post: JTaylor2005
  How much is reasonable for a timing belt replacement? JTaylor2005 2 2,262 19-02-2015, 09:01 PM
Last Post: Toms306
