How much is reasonable for a timing belt replacement?
Hey all,
Car is coming up for timing belt soon. Any ball park figures of how much it should cost?
Cheers Smile
Jack
Cambelt kit £55 + vat
Water pump £17 + vat
Then factor in coolant/distilled water and labour if you're not doing it yourself but they are fairly easy.
Pretty easy on a HDi...just try not to slip off the crank pulley when rotating the engine and smash your finger into the brake caliper, I have a permanently disfigured nail from that. Sad lol
Couple of hours work for a garage, little more if it's your first time. You'll probably want to change the aux belt at the same time.
  Cost of Timing Belt and Water Pump Replacement? JTaylor2005 7 6,018 12-02-2018, 03:29 PM
Last Post: JTaylor2005
  Best timing belt kit and water pump? JTaylor2005 13 7,990 23-09-2016, 10:11 AM
Last Post: BiG K
  Timing Belt? JTaylor2005 29 16,268 07-10-2015, 05:02 PM
Last Post: beulah
