annoying knocking noise coming from engine bay
Recently my car has decided it likes to knock whenever i either speed up or slow down and it will knock quite loudly if i come off the throttle.
Originally thought it could be engine mount?
Any ideas would be a help Smile
306 HDI, soon to be XUD
Have a ganders at your engine mounts. Normally bottom one to knock. If they all look fine, get the wheels in the air and see if you can find any play.
NiallHarper Wrote:Have a ganders at your engine mounts. Normally bottom one to knock. If they all look fine, get the wheels in the air and see if you can find any play.
Yeah i will have a gander tomorrow, they a pig to change?
Bottom ones arnt the nicest because the o/s driveshaft has to come out. If its either of the top ones, there quite easy.
Just don't do what I did and drop the gearbox mount without anything under the gearbox lol
ahaha thats skill mate!
Quite cheap to replace the mounts?
Gbox mount was 8 quid, top was 12 and I haven't done the bottom but it should be cheap. Needs pressing though.
I hope so lol
Sounds like bottom mount or a cracked chassis around the top mounting point.
Grab the top of the engine and rock it and see where it moves
a cracked chassis doesnt sound so great!
declantg Wrote:a cracked chassis doesnt sound so great!
Not as bad as you would think. Will only take a couple of minutes for someone to weld up.
Just checked it and rocked it forwards and back, right hand side has more play
Thats what iv got. Gonna weld it tomorrow
Vehicle repair and servicing in the midlands pm for detailsĀ
Current cars
Subaru Impreza 2.0d - Daily
can you feel the knock through the gearstick and steering wheel? could be subframe bolts coming loose.. mine came loose during an autotest once, thought it was a snapped engine mount until i lifted off on the way home and the steering wheel started moving back and forth..
lh_4827 Wrote:can you feel the knock through the gearstick and steering wheel? could be subframe bolts coming loose.. mine came loose during an autotest once, thought it was a snapped engine mount until i lifted off on the way home and the steering wheel started moving back and forth..
Will have to have a look tomorrow but cheers man Big Grin
  Rear Suspension fettled - still a knocking noise! (ZX) beko1987 4 3,424 17-08-2015, 01:53 PM
Last Post: beko1987
  Knocking noise!! Help connorp 5 3,527 04-05-2015, 09:18 AM
Last Post: connorp
  Knocking noise after brake change LewisG 4 3,065 17-02-2015, 12:13 PM
Last Post: Toms306
