Knocking noise!! Help
Something at the front left of my 1999 306 xs 1.8 petrol is making a horrible knocking noise over any bump but not round corners or anything else only over bumps, and I mean every bump, at first I thought it could be some plastics but I now know it's not and I need to find out what it is, any help will be much appreciated.
Cheers
probably a drop link worn they link the anti roll bar to the suspension strut one on each side
knocking on left could be the right side droplink and visaversa or could be the same side as the noise
GTI6 Info
Thanks man, how would I check this? And is it easy to replace?
Jack it up, crowbar or breaker bar and wiggle it about and you'll probably see movement if it's nackered, could also be a ball joint mate
Thanks
It was the drop links, cheers guys
  Rear Suspension fettled - still a knocking noise! (ZX) beko1987 4 3,515 17-08-2015, 01:53 PM
Last Post: beko1987
  Knocking noise after brake change LewisG 4 3,149 17-02-2015, 12:13 PM
Last Post: Toms306
  annoying knocking noise coming from engine bay declantg 15 10,611 28-12-2011, 06:43 PM
Last Post: declantg
