3-door tilt levers - replaceable?
My car has some GTi6 leathers in but the lever handle on the drivers side seat has broken a bit. You can still operate the tilt/slide mechanism but I wondered if the handle itself could be replaced with one from a scrappers?
More to the point, how would you even go about replacing it?
Important as in 6 weeks time that will be babies side of the car too...
I'll get a picture up later.
[Image: Sig500x130.png]
Can anyone shed any light on this? I forgot to get a photo but will do later on if it helps.
Basically the lift handle to tilt the seat handle has broken a bit, I'm wondering if it can be replaced or whether I would be better off sourcing another drivers seat altogether.
I would imagine it is removable anyway, given that the handle is larger than the aperture it can only be fed externally.
I would unhook the seat backing and roll the seat up, see what you're faced with. If it's broken internally it will be obvious, and I would imagine you can exchange a working part.
I'll be back in Peterborough soon if you get stuck with anything major.
Edit:
Servicebox agrees with me:
[Image: hb89a15a.jpg]
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
11 quid new iirc.
But there a bitch to remove once there on there though.
[Image: sig.jpg]
Got some pictures now.
It's literally just the little plastic bit on the end which is broken - can this be purchased separately? (or does someone have one kicking around?!)
[Image: EDD45D05-E65C-45D9-AF5B-07528C07C290-299...E3D883.jpg]
[Image: 80902219-BEF2-4B46-ADD9-59C1533125B1-299...5702E0.jpg]
[Image: 5111D091-F2B0-4382-9CF2-B335349929A6-299...9A8A31.jpg]
[Image: B34DA6C7-A6B4-4537-9D70-4E5D519A747B-299...4B0E00.jpg]
Yup, £11.26. Probably worth just going to Pug and ordering one.
Part number is 8905 48
(just so I don't have to go back into Service box to look it up again...)
Need to order two myself just can't face parting with £22 for them.
[Image: sig.jpg]
Question 306 XRDT driver seat tilt quistion with pictures 306__xrdt 0 1,606 02-09-2012, 11:16 AM
Last Post: 306__xrdt
