lowering springs wanted
after a set of lowering springs if poss. 30-40mm. as i am gonna buy a replacement rear axle which is already lowered.
cheers.
Is that for the HDi mate? Smile
I've got a almost new set of 40mm spax springs that will fit a hdi. 35 posted.
scott- yeah its hdi. i did get offered my mates gti6 spring but ive been told that the gti6 is heavier and it not worth
puttin them on my hdi.
niall- sorted payday tomorrow hopefully. ill let you know.
Gti springs will drop it 20mm if your lucky. Pm me mate when your ready.
(29-08-2012, 07:26 PM)Will_306_hdi Wrote: after a set of lowering springs if poss. 30-40mm. as i am gonna buy a replacement rear axle which is already lowered.
cheers.
Hi
I've got a pair of new unused 40mm lowering springs for my 306td but didn't fit them. Would they fit your 306? Probably want £25 for then
BW
(29-08-2012, 08:05 PM)Niall Wrote: I've got a almost new set of 40mm spax springs that will fit a hdi. 35 posted.
1.8 springs might fit... But for the exact reason you took them off your gti, they won't be "right"
They'd be more like 50-60mm with the extra weight of the HDi lump over the 1.8 too
50-60mm? They will be spit on then
50 - 60 yes... the right spring rate.. noooo lol
(18-09-2012, 04:26 PM)Midnightclub Wrote: 50 - 60 yes... the right spring rate.. noooo lol
minor details, just uprate the ARB lol
according to spax when i ordered them, them particular springs are for all the dervs, TUs and the 1.8 so should be fine@!
Well that's total bollocks, they'll be right for 1 of the engines, but not all of them. Just think a HDi and a tu5 on a set of scales... Lol
(18-09-2012, 09:28 PM)Connor Wrote: Well that's total bollocks, they'll be right for 1 of the engines, but not all of them. Just think a HDi and a tu5 on a set of scales... Lol
yeah i know weights are different but think how much money they wouldnt make if they made a different spring for every model? probably grouped like that and the rates are based on a average or something like that
i've got a pair of 40mm spax ones for gti, £35 posted. cant imagine te dw10 and xu10 blocks are too far off in weight?
Peugeot 306 XSi, S16, Hdi, Gti, GTi6 Spax Lowering Springs - S027016
Chassis Type: XSi/S16
Lowers 40mm
i have these in my HDI estate yes they drop by that much but they are too stiff its a hard ride
  306 lowering springs floz123 3 3,847 21-04-2017, 06:34 AM
Last Post: ozonehostile
  Wanted: Hdi Lowering springs ct-hdi 3 3,174 06-02-2016, 05:44 PM
Last Post: WiNgNuTz
  Wanted: 40mm lowering springs gti6/hdi ozonehostile 1 2,414 27-12-2015, 08:58 PM
Last Post: roland rat
