Gti6 bottom rad pipe seal.
To cut a long story short after replacing the engine in the 6 and the round seal for the bottom hose that goes in to the radiator was f*cked. So ive orderd some from pug and got my mom to pick them up today. I used my vin on service box to get the part number.
Have got the parts today and its just a oring that pug have gave me now the one that came off the car looks like a thick o ring with a groove around the out side.
So my question is will the orings pug have gave me be ok? I dont want to fit them if its going to start pissing out water again
Thanks in advance lee Smile
Yep common issue that they break down and as soon as you remove the hose, it never seals again. Clean the metal end up with sand paper and fit the new o ring.
Just be careful because Peugeot do two different ones. Iirc both have the same ID but have two different ODs that are something stupid like 0.5mm different.
Ok mate thanks i used my vin on service box but the oring fitted to the car is compleately diferent style to the one they have supplied. As in its not as wide. Do you know if pug changed them to a standard oring?
No don't think so. I assume they have given you one that is square on a cross section with a groove cut out of it? That's what I had and it was fine. Never leaked a bit.
Thats what i have got fitted at the mo but they have gave me normal o rings Sad do you have a part number for the one you got mate?
Choice 1
ID 31mm, thickness 3.6mm, until RPO 7972 P/N 133994
Choice 2
ID 31mm, thickness 3.5mm, from RPO 7972, P/N 1343Z4
Both about 70p ish
Will check the part number 2moz it was defo one of them 2 tho. But they have gave me normal o rings with no grooves exc. Could be a fail Sad
I had to but 5 and they came to £6.06
You got bum raped then! Is yours a push fit into the radiator or does the hose clip over the radiator?
Push fit Into the rad. with the metal clip to hold it in to the rad. Similar to the top hose that goes in to the thermostat.
Yep wrong seal then by the sounds of things. You want the square one with the ridge in it. It's a pita to fit to the hose if the lip is distorted in the slightest!
Dam bloody parts department i gave them the part number i got off service box useing my vin number they must of f*cked it up. Sad
Are them part numbers you gave me for the seal i will need if so i will re order them one of them will fit Smile
Cheers for the help mate much apreciated you have been repped Wink
This is the part i orderd should it be a normal o ring?
Well i have fitted the part above and it is compleately different to what was fitted to the car but it does fit and seals fine Smile
  Turbod GTI6 on Ebay without bottom end mods MY95 14 8,952 02-04-2015, 03:09 PM
  scorpion gti6 straight pipe on the 1.8 xs ?? jjenn20 6 3,271 25-01-2015, 09:40 PM
  Gti6 bottom pulley head scratcher Marcdimma 4 3,560 15-11-2013, 06:22 PM
Last Post: welshpug
