Temperature
Temperature
So today my temperature went over 90 for the first time since I've owned the at. Worried me a little Sad
Completely knew to cars, how do I check coolant, what do I look for how to I fill it etc etc
Thanks guys
(16-08-2012, 06:56 PM)bowers Wrote: So today my temperature went over 90 for the first time since I've owned the at. Worried me a little Sad
Thanks guys
Take the rad cap/header tank cap off*
peer in, see what the level is like
top it up so it's sat at the max line Smile
*When engine is suitably cold!
Cheers mate Smile
Don't worry dude, these TUs like to run nice and warm.
My 1.6 runs are 95-97 as standard and has done for 2/3 years
I assume it's a tu. how do I tell?
What size is it? If its a 1.6, it's a TU. if its a 1.8 or 2.0, it's a XU. also, if its 16 valve in a 306, it's definately a XU. All 306 diesels were XU but only 8v.
The only 16v TU They did was the 106 gti which was a 1.6
They generally do wander up and down the temp scale in hot weather - they don't hold much oil or water so the temperatures change fairly quickly in traffic or under load.
Yeah shouldn't worry bud mine runs at 90 all the time then you boot it and goes over it just the engines lol
