Change off rear shock absorder (both) 306 XRDT
Hi Blush any difficult jobb to change the rear shock absorders on a peugeot 306 XRDT?
Is there any good guide on this forum about that jobb?
I fixed the Bosch dieselpump with a new bolt and passed the mot with that, but didd not passed becouse off defect rear shock absorders.
Thanks for the help Blush
[Image: 62941977.jpg]
no it's really quite easy . . . . .Smile
Ok thanks Smile
(14-08-2012, 05:04 PM)306__xrdt Wrote: Ok thanks Smile
just undo the bolts, you might need another jack under it to take the weight off, tap the bolt out with a hammer and a screwdriver or summit, replace with the new shock and bolt back up . . . .that's about it as i remember it, been a while since i did them though . .Smile
Ok many thanks for the info, i need also replace the left front balljoint but i have done that before easy jobb Smile
  Rear shock bushes Tidoh2016 2 2,891 12-05-2018, 09:38 AM
Last Post: pug306driver
  Rear beam change LironTurbo 11 6,609 21-07-2017, 02:30 PM
Last Post: Mighty306
  Snapped koni rear shock absorber, junk or fixable? Spoonaltap 5 4,290 21-03-2017, 01:28 PM
Last Post: Spoonaltap
