Clock/Radio not working
Since doing my Hg when tge car was off the road with the battery disconnected for a few weeks my clock and stereo dont work.
The clock has the back lights lit but no display, tried 2 different ones, same problem.
The stereo does nothing at all, comletely dead. There is 12v at the back of it, checked with a meter and my boost gauge I wired in there which does work. The stereo itself is fine, checked it on the missus golf today. While I had the meter out I checked accross the yellow wire to ground and this showed 0.41v regardless of key position, what should this be reading?
Lastly checked fuses 1 & 25 which the manual shows are for the clock and radio.
Help required please chaps and muchos rep for anyone that can solve this, need tunes!!
HDi Cabby Project Click
earth wire off somewhere ??
(10-08-2012, 09:11 PM)daddyfixit Wrote: earth wire off somewhere ??
Where should I check. Any ideas what the reading off the yellow wire should be, is it another 12v switched live?
why dont you just try and patch the earth? rule that out?
I'd check all the fuses and sort the earth
All fuses are fine and I cant find any earth wires that have come off. Given up with it tbh, the new owner can have fun with that one!
check the earth strap from the battery to chassis and the one by the pedals
  Rev counter & clock not working AustinAR 0 1,972 28-03-2014, 12:32 AM
Last Post: AustinAR
  Radio and clock permanent live? Mitch 10 4,690 11-12-2013, 08:23 PM
Last Post: Mitch
  Clock not working Willo 10 6,587 17-02-2013, 07:29 PM
Last Post: Willo
