gear knob
replaced my standard knob with a sparco one, pulled the plastic stuff off from underneath. now i want a hdi knob, and i have no plastic stuff to make it fit properly. anywhere i can get some?
(02-08-2012, 09:26 PM)bowers Wrote: replaced my standard knob with a sparco one, pulled the plastic stuff off from underneath. now i want a hdi knob, and i have no plastic stuff to make it fit properly. anywhere i can get some?
The scrap yard, home to everything you'll ever need
insulation tape round the gearstick and tap the gearknob on with your palm job done
Team Doesn't own a 306
Impossible to get off in one piece haha.
And I user insulation tape with the sparco one it still works its way loose
Try using Duct tape instead......and a little more of it lol. That's what I used and my gear knob stays put.
Failing that get a second hand gear stick with the plastic section for the gear knob from a scrappers, they're easy enough to remove as long as you can get under the car you're taking it off.
  Will this gear knob fit? Suggestions for a better one? Charlie0 3 4,737 16-09-2020, 03:53 PM
Last Post: ekjdm14
  Wanter Gear Knob Pug0BZ3011 1 2,756 19-05-2016, 05:22 PM
Last Post: WiNgNuTz
  Which is this gear knob? vandalzd 0 2,145 22-09-2015, 05:02 PM
Last Post: vandalzd
