Phase 1 headlights onto Phase 2
I have a set of single optic phase 1 lights to go on but the phase 2 has different plugs. If I get a set of twin optic lights do there plug into the standard plugs or do I need the connector and some abit of the wiring to be able to join them in?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
You'll probably need to swap the plug, afaik the ph2/3 has a multiplug and the ph1 plugs are individual. Also what are you doing about the slam panel? You gonna bodge the lights on or you swapping it?
Swapping it putting a full Phase 1 front on bonnet bumper ect. Ye its all one plug on the phase 2 so if I break them open and take the wiring out I can plug the original multiplug in then wire the phase 1 bulb holder to the loom so I can just unplug it if I ever fit phase 2/3 lights again?
Blaze 1.6 Dead
  306 xsi phase 3 central locking issue!!! Seabrook3607 2 3,006 16-01-2016, 08:02 PM
Last Post: Seabrook3607
  1.6 Phase 3 Dash Board Issue Jama 3 4,318 09-09-2015, 02:05 PM
Last Post: Jama
  PHase 1 3 door bouncing window?? Redordead89 2 3,108 21-07-2015, 09:28 AM
Last Post: Toms306
