Need: Rear brake hoses and handbrake cable - disc
Lot of knowledge here, so cheapest for best quality please
Looking for:
- new rear brake hoses for a disc beam from an XSI - going to be fitting it to my 306
- handbrake cable for a disc beam also.
AND/OR
discs and pads to replace on the back could be of benefit.
ebay im assuming would be easiest or pug part number and price if you have it would be delightful!
much love x
http://www.ebay.co.uk/itm/PEUGEOT-106-2 ... 20b3662705
For rear discs and pads.
Motor factors for the hoses (unless you go braded) and same again for the cables.
[Image: sig.jpg]
Chris Wrote:http://www.ebay.co.uk/itm/PEUGEOT-106-20...20b3662705
cheers mate!
yeh id preferably want braided hoses
have you got a part number at all for these?
Nope, get on ebay for the hoses, and just go into the factors with a reg no and they'll do the rest.
[Image: sig.jpg]
Chris Wrote:Nope, get on ebay for the hoses, and just go into the factors with a reg no and they'll do the rest.
reg number i havnt got im afraid, im upgrading to a disc beam, requires a different cable - i'll search for and XSI numberplate Doh
cheers mate!
FYI ginge, all rear discs and pads are exactly the same and same goes for the cables Smile
Mines 2.0 16v xsi with disc beam, can use my number plate it's W979 LCD Smile
No thats my point matt, you dont need a reg cause there is only 1 type of rear disc/pad and handbrake cable is either drum or disc
Ahh right knew I should have read your post before posting hahahah
is there no size difference between gti/xsi/s16 and/or caby's?
I thought there was but there must not be. Anyway my reg is up there ginge can check that?
Nope, all rear brakes are 247mm non vented 8mm thick discs that use the same pads.
Most psa cars of the time use the same.
Cabels are all the same too.
The boxset up there is a bargin price for mintex items too.
[Image: sig.jpg]
ginge191 Wrote:is there no size difference between gti/xsi/s16 and/or caby's?
No difference in the brake set up atleast, just the "sport" models and estates are stiffer
I think the cabby cables are slightly longer, when I got my cables he said they list seperate ones for the cabby but the actual brakes are the same
[Image: SDC10442-1.jpg]
Bruv, if you want braided hoses give Swampy a ring. He's on the Gti6 forum http://www.306gti6.com/viewprofile.php?id=1096 It's worth a try although I don't know if he does them now. Avoid the Goodrich ones because they are not the right size and cause the hoses to hub on other parts of the suspension. That's what happened to Warlord0 on .net. I payed £45 all in for braided hoses from Swampy although I think he said they went up to £55 now, but still a massive bargain! Some people complain that he is slow to deliver although mine arrived almost instantly. I've had them on three months, it makes a noticeable difference to pedal feel, although there is still too much 'dead space' in the travel, you need to upgrade to a Gti6 master cylinder if you want to get rid of that. That's what I plan to do!
Edit: You can buy each pair from him as well, but you might as well do the full set.
about to order - how come these are so cheap??
http://www.ebay.co.uk/itm/Peugeot-306-R ... 20bb82f15a
surely they're as good as any??
I wouldnt buy those, £5 for your brakes? no thanks...
Connor Wrote:I wouldnt buy those, £5 for your brakes? no thanks...
doesnt answer my question DAMN YOU!!
...why are they so cheap, as i said - hose is hose surely?
Cheap materials probably
assuming these would still be fine to use on my disc beam, ja?
Also, can anyone find me somewhere online i can get the correct handbrake cable - ebay perhaps? i dont have the time to get to a dealership - LOTS of work over festive and new year times.
THANKS!!
ok this is doing my head in now - I've found "APPARENTLY" the correct hoses, they're showing different sizes, im looking on Eurocarparts for it using the reg plate of the car which the beam come from - cany anyone confirm the sizes for the brake hoses needed for the rear on each side...
OR even better give me a link to them
REG is M548 ORW (thats the car which the beam come from.)
Mate give swampy a shout, full set of lines for £45
Connor Wrote:Mate give swampy a shout, full set of lines for £45
i dont want to be spending £45 on a set of lines.... ECP they're £12 each, bosch lines... + 25% discount on the pair... its nearly half the price.
on 2nd thought, reading the thread you can buy them seperate... hm may be worth it - anyone got a GTI account and can pm on my behalf?
He's on .net too mate
Connor Wrote:He's on .net too mate
I emailed him anywho, seems through the GTI thread he does orders in bulk... I'd need them within the next week or so, so unless he has them in stock. We'll see
ANYONE else have a link to the correct lines... this is becoming painful Sad
No he does them to order... he put a thread up earlier, he sells them on ebay to... do i have to do everything for you? Shesh... give me 2 secs
Here http://www.theywhoshallnotbenamed/forum/showthread. ... highlight=
cheers babe..
handbrake cables done - eurocarparts
brake pads - ebay mintex - cheers chris!
rear hoses ordered - swampy sorted these out - what a ledgend, rear ones only, a nice colour reaasonable price!
  Do I buy? rear brake pipe corroded, covered in grease or other material pipes Charlie0 3 13,294 18-04-2019, 10:14 AM
Last Post: Mighty306
  Uneven brake drag on rear wheels balkan_bozo 2 4,053 21-10-2018, 11:10 AM
Last Post: balkan_bozo
  Rear brake compensator leaking Ben 4 6,028 24-04-2018, 07:11 PM
Last Post: Ben
