Threads: 178
28
Car Model/Spec: HDi!
Given 1 thank(s) in 1 post(s)
whats the differences between a '6 and a hdi's suspension set up?
Bearing in mind that ive got the meridian and ive got coilovers up front with gaz rear shocks and a lowered torsion...whats best way to the back a bit more planted especially! Fed up of my ass trying to overtake me!
Threads: 208
60
Given 5 thank(s) in 5 post(s)
Start with gti ARB`s Front and rear. Torsion bars if you wanted to go that far. And a good set of coil overs will make all the difference
Threads: 183
20
Car Model/Spec: moonstone hdi #2
Given 8 thank(s) in 8 post(s)
Arbs and torsion is my next plan
Threads: 82
27
Car Model/Spec: E92 335i, GTi6, HDi S2
Given 22 thank(s) in 22 post(s)
Buy some decent tyres sean?
Yeah 6' has IIRC thicker ARB's, 20mm lower , thicker torsion bars, better shocks..
A HDi Dturbo will have all those parts already though
Threads: 208
60
(12-07-2012, 02:17 PM)Midnightclub Wrote: Buy some decent tyres sean?
Are you reading this? Its a merdian. I.E for granny to run down the shops and get her shopping spec. Lol
but as danny said tyres should be number one thing to.if you havent already goodens. Parada spec2's or toyo T1Rs are the best for under £200 for 4
Threads: 178
28
Ive got kuhmo ku31's on, and i swear by them! But will look into rear arbs. Cheers
Threads: 581
195
If the back end feels a bit loose (giggidy) it's generally down to ruined beam mounts. I've just done them on my 6 and it's transformed the car.
Threads: 63
26
Car Model/Spec: GTi6
Given 0 thank(s) in 0 post(s)
(12-07-2012, 02:56 PM)puglove Wrote: (12-07-2012, 02:17 PM)Midnightclub Wrote: Buy some decent tyres sean?
Seconding the t1rs!
Threads: 82
27
(12-07-2012, 02:56 PM)puglove Wrote: Are you reading this? Its a merdian. I.E for granny to run down the shops and get her shopping spec. Lol
Am i reading this? Are you? Lol.. whats the thread title.......
Threads: 138
72
Car Model/Spec: Mincebus
(12-07-2012, 03:37 PM)Midnightclub Wrote: (12-07-2012, 02:56 PM)puglove Wrote: Are you reading this? Its a merdian. I.E for granny to run down the shops and get her shopping spec. Lol
If we're going on the title, the difference is in the fuel type....
srsly though, I would start with rear beam mounts, then check your wishbones. I had a lot of play in a p-bush and it made it unbelievably skittish in the twisties; back end always trying to overtake.
Little things will also help such as checking the tracking; toe-out will result in improved turn-in, but a more twitchy car, toe-out will result in a more planted feel, but a less sharp toe-in.
You'll also want to check the rebound settings on your rear shocks. If the spings are too hard up front and the rear is too soft, it'll result in chronic mid-corner understeer. The opposite will occur if the rear is set up too hard for the front springs....
/adenoids.
Astor 'X' 4 GTi6- 6 - SOLD!
Threads: 208
60
12-07-2012, 04:44 PM
(This post was last modified: 12-07-2012, 04:44 PM by puglove.)
LOL my bad  reading two threads at once lol, BUT still im sure he has a 5 door meridian and they dont have the same set up as a hdi Dturbo do they?
Threads: 82
27
No, they don't.. I never said they did either lol I was just saying haha
Threads: 208
60
Sowie danny didnt mean to seem short earlyer! now i read it back it seemed a bit off, wasnt ment to
Threads: 78
49
Quit yo jibber jabber fools
Threads: 82
27
It's alright babes I forgive you
Threads: 208
60
AAAAwwww i knew you'd understand
Threads: 541
124
Is your rear beam lowered? If not this is your problem IMO.
Threads: 581
195
(12-07-2012, 09:24 PM)Dum-Dum Wrote: Is your rear beam lowered? If not this is your problem IMO.
Yep because lowering is the answer to everything.....like involuntary going off roading on a verge?
Threads: 117
119
13-07-2012, 07:36 AM
(This post was last modified: 13-07-2012, 07:39 AM by Poodle.)
Another vote here for checking your rear beam mounts.
(12-07-2012, 03:40 PM)Ed Doe Wrote: Little things will also help such as checking the tracking. Toe-out will result in improved turn-in, but a more twitchy car; toe-in will result in a more planted feel, but a less sharp turn-in.
Edited to avoid confusion (and bad grammar :p).
^^^ This is very valid too, adjustable rears aren't a fit and forget option. And FYI, adding some toe-out will accentuate the skittishness you're experiencing, mine feels a lot like i'm driving on greasy roads all the time, but i refuse to buy new beam mounts and shocks when i'll be moving the car on in a few months lol.
Threads: 82
27
Sean, how much have you got the rears set to? Think i had mine set to about 180 degrees on the dial and then did another 90 degrees and that seemed just about right
