Only getting max boost around 16/17 psi with the wastegate arm on last 2 turns and running max fuel! Also any ideas on which turbo I have??
306 dturbo s xud 1998 S-reg
Scott
Scott
Turbo Boost and model
306 dturbo s xud 1998 S-reg Scott
09-07-2012, 08:23 PM
Could be a worn wastegate being pushed open or a boost leak
Don't know what turbo it is though. Being a later model I'd think ko3 or similar
09-07-2012, 08:24 PM
turbo seems rather leaky
Perv 306 1.6 5 Door Hore - Sold 110bhp 207 Hdi Sport - Used as a Brake 173bhp T25 Ph1 Diablo Dturbo - Scrapped Thirsty Bitch Volvo 850 Estate - Sold 51bhp Berlingo Nad DT Van - Sold Slow as f*ck Dispatch Work Horse www.prestige-auto-care.co.uk
09-07-2012, 08:26 PM
(This post was last modified: 09-07-2012, 08:29 PM by scottbmxer.)
Ive noticed in first or second before the the boost has just dumped at around like 3500 4000 revs causing the car to slow down massively like I put the brakes on!
going down motorway and stuff it will stay at a constant boost no problem Btw when I mean max fuel i mean 45degree's or slightly more on lucas pump!
09-07-2012, 09:06 PM
The manifold looks different to my old T2 and k14 so i'm guessing it's a GT15
Stage 2 XUD Sedan
09-07-2012, 09:10 PM
That's a k03 should got more out of it than that mines boosting 1.4bar .
11-07-2012, 03:01 PM
(This post was last modified: 11-07-2012, 03:08 PM by scottbmxer.)
(09-07-2012, 09:10 PM)4WayDiablo Wrote: What you mean before "the boost has just dumped" sometimes the boost just dumps around those revs in first and maybe second! I just loose all pressure and it slows the car down massively like I have put on the brakes. (09-07-2012, 09:10 PM)ash23 Wrote: That's a k03 should got more out of it than that mines boosting 1.4bar . how much did you tune your lucas to get that 1.4 bar?? and is your waste-gate arm really short like mine? like on the last few threads
11-07-2012, 03:09 PM
(This post was last modified: 11-07-2012, 03:13 PM by scottbmxer.)
(11-07-2012, 03:08 PM)Mowle5677 Wrote: have you checked all your piping?seems fine to me but im not great with cars lol this is a video of it running a few months back at stock - http://www.youtube.com/watch?v=vDkf-WcYe...ature=plcp
11-07-2012, 05:34 PM
(09-07-2012, 09:10 PM)ash23 Wrote: That's a k03 should got more out of it than that mines boosting 1.4bar . 28psi here (1.9 bar) on a K03 here! But sounds like a busted turbo; I shouldn't cut off, at higher rpm, the turbo will start to loose boost..
Phaes 1 GTI 6 - Onyx Black
11-07-2012, 05:52 PM
if it is a busted turbo then drive it normally but i say its bigger turbo time
![]() Team derv FLAME and CONROD spitters
12-07-2012, 08:45 PM
Was going to upgrade to a T2 what do you think??
12-07-2012, 11:04 PM
go big, or go home. td04 or the like
![]() not that i know anything about dervs, but from what i know, the t2 is the 'best' standard turbo they put on. might as well get a big un on it for more gains and whatnot Member of the 99% warning or you're nothing club |
| Maximum safe boost on 2.1 TD on std. turbo? | B1ack_Mi16 | 18 | 12,616 |
19-12-2013, 01:15 PM Last Post: Dum-Dum |
| aux belt tensioner a/c model removal? help | CJ_Derv | 2 | 2,944 |
09-06-2013, 11:03 AM Last Post: CJ_Derv |
| TD04 Model Codes | bigcheez2k3 | 2 | 3,193 |
09-02-2013, 10:49 AM Last Post: Ruan |
