ffs boost leak
ffs boost leak
I'm currently chasing a epic boost leak that's winding me up.
So far I've change D seal turbo to top mount pipe the top mount cooler all new jubilee clips but still have a boost leak I've now jubileed the t piece on the boost compensator and no better it seems to start at about 10psi and starts screeching at 14. Anyone know where this leak could be I had this at fcs.
Started after a head change. Could it be inlet bolts loose? Turbo is untouched at present so surely not leaking from the unit its self?
Here's a stupid question to would it leak from the rocker as I've noticed there is a washer missing from one of the three bolts but didn't think there would be much pressure in there
Hope someone can help
[Image: VcvTtst.jpg]
Wouldn't leak from the rocker
And from what you say the inlet is the last thing it can be so yeah one must be loose
Shine a light down the back around the ports and you can usually tell if you have a leak
Manifold bolts..............there is nothing else left if your sure that everything else is tight Smile
Team Orange Engine Bay
As said your manifold must be blowing, did you use a new gasket? Did you put ALL the bolts back in?
is the lda top screwed down tight?
Everything else checked yeah Ida screw? Not so sure
Darren it was a new gasket but was a gasket paper kit for xud9 t.
Would you suggest taking it off and doing it again?
Cheers guys for the advice
(03-07-2012, 02:55 PM)zekegti6 Wrote: Everything else checked yeah Ida screw? Not so sure
not the screw - but the four bolts/screws holding the top down, are they tight?
Exhaust manifold blowing from gasket?
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Im going with inlet manifold try doing the bolts up first sometimes they are easy to forget.
Bye Bye D-Turbo
Ok mate ill have a try mate cheers
Hi mate did you find the problem as im having similar but not as great psi leak
ta
[Image: J5hxCcC.jpg]
yeah the guy who repaired it first time left 1 exhaust gasket off and 1 ilet one
  boost leak ? Motatalk 3 2,825 19-06-2015, 07:46 AM
Last Post: Dave
  Boost leak... philpemberton94 6 4,704 13-06-2014, 10:31 AM
Last Post: toseland
  boost leak? willJspears 11 6,260 02-02-2014, 05:22 PM
Last Post: willJspears
