ph2 lucas to bosch pump wiring
Sad
hi guys does any 1 know what wires do what on these pumps as im going from lucas to bosch and i really wanna keep the immobileser
cheers for any help
If you wanna keep the immob, you need to tear the mini ecu pack off the back of the lucas pump (drill out security bolts), then cut the 2/3 wires that go to the exsisting lucas solid, then find out which one goes live with the ignition on and immobiliser active, and connect that to your bosch solid, and just tape over the other wire / 2 wires.
  Wiring for Lift Pump mspdan 3 2,333 26-12-2013, 08:43 PM
Last Post: cully
  bosch pump feed (with pics) bufter 3 3,252 15-07-2012, 04:01 PM
Last Post: bufter
