Wiring for Lift Pump
hi guys,
after bit more help again, i have a wiring issue with my 306 HDI and it wont start or send power to the lift pump.
Anyway im trying to trace the lift pump wiring in the car and was wondering if anyone know the routing and how easy it is to get to?
Also where it connects in the car, as i have established i have power in the engine bay just none at the connector at the pump
thanks in advance
Wiring from the engine bay comes in to the cabin at the big multi plug behind the wiper motor, then goes into the dash loom and then the cabin loom is 2 plugs (red and grey iirc) which connect to the dash loom under the glovebox.
thanks mate thought it was passenger side will go and have a play, spot on for that buddy
http://306oc.co.uk/forum/thread-19870.html
locking thread cause youve started two on the same subject
  power to phase 1 lift pump HDIkyle 9 5,944 30-07-2012, 11:49 AM
Last Post: mechsman
Sad ph2 lucas to bosch pump wiring chippyba 1 2,466 04-07-2012, 07:18 AM
Last Post: darrenjlobb
