Electrical problem URGENT help needed!
So have just been out to fetch myself a pack of ciggies merrily making my way down the road in the car and true to Lincolnshire in the last 24 hours we've had torrential downpours so windscreen wipers swishing away get my fags and start on the way back start the car back window wiper going happily away turns the fronts on and *NOTHING* so what is it windscreen wiper motor, fuse what?
As I say the back is working fine but the front isn't going anywhere had to make my way home with my arm out the window manually wiping it so I could f*cking see!
Problem is I never got an owners manual with the car so if someone could please have a look in their book if they have one and tell me what the fuse number is and which are the spare fuses it would be much appreciated!
Failing that: Anybody have a spare wiper motor? Itwasntme
This should help........http://www.peugeotlogic.com/fuses/fuses306/fuselist7.htm
Wiper motor then...Bollocks
Headlights work fine as does rear window wiper which are both on the same fuse...my pocket is getting lighter already!
I would check all the fuses in the box and replace any that are blown that you might not know about as peugeot being peugeot I wouldn't totally believe the diagram, lol
Team Orange Engine Bay
I used to have this intermittent fault only every so often mainly when it blasted it down lol,
I used to have to move the wipers to get them going as they used to get stuck try this see if they get going,
Im stripping the old motor down and cleaning this weekend and putting up for sale if you interested but may just need stripping and cleaning im sure ive seen a good guide in this forum for this Smile
[Image: J5hxCcC.jpg]
got one you can for £10 +p&p
Sorted it in the end mate the drivers side wiper arm had somehow undone itself tightened it back down and it was fine!!!
Member of Team Rather be Gay than Ginger
Member of Team Holey Engine
[Image: IM_sig.jpg]
Mine has started playing up recently on the auto setting they have a mind of there own, relays clicking and wipers judder. But at fine on other settings when the relay is not clicking. Quite annoying
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
  Electrical woes bashbarnard 13 7,382 06-06-2017, 11:16 AM
Last Post: bashbarnard
  Electrical help!!! Pompey306mark 7 4,453 16-08-2014, 04:47 PM
Last Post: Pompey306mark
Rainbow I got a electrical problem tomosy10 9 5,549 19-03-2014, 12:29 PM
Last Post: Razorback_Rob
