Given 117 thank(s) in 116 post(s)
Laser alloys?
I reckon you can hammer a small deep socket on the centre but not sure it'll grip enough. Irwin bolt extractors weight be worth a try.
Threads: 47
Car Model/Spec: XSi 16v
Given 71 thank(s) in 69 post(s)
Doesn't look like there is space to hammer a socket on those. Had a similar problem n my local garage got them off by welding nuts to them n then spinning them off. Cost me £20 I think.
Threads: 13
Car Model/Spec: lots of 206s
Country:
yeah those type you can either weld a nut on, or it's worth trying a few local tyre places and see if they have a key that'll fit as some keep a selection handy because of the nature of their work, and these are quite a common type of locking nut.
Also, get some standard nuts to replace them afterwards. Honestly my biggest hate has to be locking nuts, who steals alloys these days?
Threads: 41
28
Given 86 thank(s) in 85 post(s)
plenty of area to smash a sacrificial 12 point socket onto that type of bolt, do the other 3 up to torque will help also.
smashy smashy!! 9/16 rings a bell.
I have also managed to drill the heads off locking wheel bolts.
Threads: 47
Angle of the picture made it look tight but definitely trust your judgement on that!
81
Given 103 thank(s) in 101 post(s)
smash a socket over the end, when that doesnt work trying to get it out will be a pain.... after that youll be onto the welding a nut on trick which you should probably try first anyway.... then after that drilling them out... yay.
81
ive made a point now never to do lockers up that tight. All happened after my locker split at the side and i didnt trust it to not break!
Threads: 47
Deep well bolt extractors eh? Good to know. Been meaning to get some Irwin's for a while but will check out the alternative.
