27-02-2020, 11:00 AM
Has anyone any info for a bench test for the MAF sensor, like reistance checks etc......
Maf sensor bench test?
29-02-2020, 07:18 PM
They aren't that simple to check.
You could compare two at constant revs say at idle and 3k rpm via the volts out on pin 5 for the flow or the volts on pin 1 for the temperature volts out.
05-03-2020, 02:53 PM
Thanks, got that info from a HDI file in info, real good info..........will be checking 12v supply ( suspect make and break contact in wires...... ) and earth and outputs...........awaiting turbo oil return pipe, £40 from pug with discount!!
| How to test a speed sensor? | jay8086 | 3 | 4,257 |
07-11-2012, 01:23 AM Last Post: jay8086 |
